By Doug Dutra
Many
performance minded SL6 owners know that there is a lot of extra
performance "hidden" inside the engine's cylinder head. The simple
fact is that the SL6 head was designed to support 170 cubic inches
(port layout & valve sizing). This tells us that air flow will be
less then adequate for the larger displacement engines (198 &
225). Even the "small" 170 will turn into a real RPM "monster" if
more cam, bigger carb. and some head porting work is done.
Knowing
that a "head swap" is a big job and that lots of time and money can
be invested into a good "performance built" SL6 head, I wanted to
review and remind everyone of the combustion chamber change made to
the SL6 head in 1968. I feel that the "revised" chamber design is a
better design for both performance and cylinder efficiency (fuel
economy) so it is worth the effort to locate and use the 1968 and
later head in order to get the most out of your efforts and your SL6.
The new chamber shape can be found in heads with and without the
spark plug tubes.
The combustion chamber shape was changed to get rid of some mixture "dead spots". These are places in the combustion chamber where the mixture does not burn completely. The main motivation for the auto makers to do this is to reduce exhaust emissions through a more complete combustion process.
Take
a look at this "new technology" combustion chamber for a "wedge type"
engine. This shows the trend to a "close chamber" design where there
are quench / squash areas. Another design feature is to try to
concentrate / direct the mixture around the exhaust valve and have
the spark plug's tip in the middle of the mixture "charge". All this
helps create a more complete "burn", which will yield more power.
This
side by side view of the two SL6 head chamber styles shows the more
open and symmetrical shape of the early chamber ( right side - click
picture for a bigger view). The area to look at is the surface where
the spark plug comes through. The early head has some dips on either
side where this surface transitions into the rest of the chamber wall
and roof. These are the "nooks & crannies" where the mixture will
not burn completely. (Another big "hiding place" is the space between
the cylinder wall & piston crown, down to the first piston ring.
This is the reason why we see aftermarket piston ring grooves moving
higher & higher up the piston crown.)
The
pointer in this chamber picture shows the extra metal added to the
exhaust valve side of the chamber, this helps to keep the air / fuel
charge close to the valve. A distinguishing feature missing from
these later chambers is
the
"half moon", dime size " dot" cast into the early head's chamber,
opposite the spark plug opening. (see
previous photo) You don't want to put a bunch of work into a SL6
head with the "dot". (most carry casting number 2206035, under the
valve cover) You do want heads with the extra metal angling in
towards the exhaust valve as shown here. There are many different
casting numbers for these "later" revised chamber heads, none have
that casted-in chamber "dot". All "no spark plug tube" heads, using
the small B-series spark plugs (peanut plugs) have the later revised
chamber design.
There
are some additional feature changes to the later heads. This picture
shows how the revised chamber has a more defined 3.400 bore diameter,
which extends up into the chamber for the first 3/16th of an inch.
(appx. .200) This creates the possibility for quench/ squash areas on
both sides of the chamber.
With
careful "blueprinting", machining and parts matching, these areas
can
be used to create a high turbulence, "closed" combustion chamber
design. The chambers in the photo above are "smiling"
because this type of chamber design makes lot's of power! - DD
