Slant Six Forum https://slantsix.org/forum/ |
A/c https://slantsix.org/forum/viewtopic.php?f=1&t=45013 |
Author: | Ross [ Wed May 18, 2011 7:20 am ] |
Post subject: | A/c |
Hey guys So as it's getting warmer, I've been wondering if my ac will work. I don't know if it really did when I got the truck back in November seeing as it was cold outside. Well on one of the warmer days I tried it, both ac and max ac. Nothing. It seems the compressor clutch will not engage. There is no burning or smoking or sqealing. Could this be an electrical problem or is it just a bad clutch? Idk if the system needs to be charged or not either. I did however, when I did the hei conversion, make sure all the wiring was correct for the engine bay part of the ac wiring, so if it's electrical I'd assume it's under the dash?! Thanks for the help Cody |
Author: | Charrlie_S [ Wed May 18, 2011 10:35 am ] |
Post subject: | |
Most likely low/out of refrigerant. there is a pressure switch, which prevents compressor operatin when low on charge. switch is usually on the drier. You can jumper the terminals, just to see if the compressor engages. Do not run it this way, it will damage the compressor, from lack of lubrcation. There might be a pressure switch by the expansion valve at the firewall, that would need to be jumpered, also. |
Author: | Ross [ Thu May 19, 2011 9:10 am ] |
Post subject: | |
Ok thanks Charlie. There are a couple switches by the firewall for the ac so I'll jump those and see if the clutch works. If so I'll get some more refrigerant for the system. |
Author: | Ross [ Fri May 20, 2011 6:44 pm ] |
Post subject: | |
Ok bypassed the switches. Clutch works. So I'm out of refrigerant, I went to shucks and the don't have r12. Where can I get r12? |
Author: | Joshie225 [ Fri May 20, 2011 8:56 pm ] |
Post subject: | |
Mexico. |
Author: | emsvitil [ Fri May 20, 2011 8:59 pm ] |
Post subject: | |
Ross wrote: Ok bypassed the switches. Clutch works. So I'm out of refrigerant, I went to shucks and the don't have r12. Where can I get r12?
ebay You'll need EPA 609 certification |
Author: | Ross [ Fri May 20, 2011 9:08 pm ] |
Post subject: | |
Haha nice Josh. What about that freeze 12 stuff? It said you need to completely empty the system. Would that work? |
Author: | Charrlie_S [ Sat May 21, 2011 3:46 am ] |
Post subject: | |
R-12 is still available, but it is pretty expensive, so you don't want it to leak out. You should really get the system leak tested/repaired. Before adding any refrigerant, you need to evacuate the system to remove any air/moisture, and I would highly recommend changing the drier. I do not recommend using any refrigerant, other then R-12 or R134a after a proper retrofit. PS: The price of R-12 has been dropping do to less demand. Most all cars that used R-12 have either been taken off the road, or have already been retrofitted. Most cars that still use R-12 are "classics" that want to stay original. Wait till you see the price for the new auto A/C refrigerant, that will be used as of the 2013 model year (possibly some 2012). It is called HO1234YF, and is projected to cost about $2,000 per 30lb drum. |
Author: | Charrlie_S [ Sat May 21, 2011 3:47 am ] |
Post subject: | |
emsvitil wrote: You'll need EPA 609 certification Legally, but individual sellers on E-bay don't worry about that. |
Author: | Charrlie_S [ Sat May 21, 2011 3:48 am ] |
Post subject: | |
Author: | SlantSixDan [ Sat May 21, 2011 5:41 am ] |
Post subject: | |
Ross wrote: What about that freeze 12 stuff?
No. Not unless you want to trash your A/C system and have to do extensive/expensive repairs and then fill it with the correct refrigerant. Use R12 or do a proper conversion to R134a (those $20 "retrofit kits" from the parts store don't count as proper). |
Author: | SlantSixDan [ Sat May 21, 2011 5:49 am ] |
Post subject: | |
Charrlie_S wrote: Wait till you see the price for the new auto A/C refrigerant, that will be used as of the 2013 model year (possibly some 2012). It is called HO1234YF, and is projected to cost about $2,000 per 30lb drum.
That's HFO1234yf (or R1234yf), and it looks like the initial price will be high, but so was the initial price of R134a. |
Author: | emsvitil [ Sat May 21, 2011 1:24 pm ] |
Post subject: | |
Charrlie_S wrote: emsvitil wrote: You'll need EPA 609 certification Legally, but individual sellers on E-bay don't worry about that. Some do, I had to scan my card and send it to the seller when I bought mine. I think ebay is requiring it. If you find a seller that only has 2 cans you probably don't need it. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
