It is currently Wed Jan 23, 2019 3:05 pm
PostPosted: Tue Jul 18, 2017 12:36 am
Car Model*: 64 Plymouth Valiant
My passenger side door hinge detent roller doesn't want to roll.
Awful noise (slightly less now, tried lubing).
Drivers door rolls like it should.
What the magic elixir that I can spray on it so it rolls?
Acts like it's rust welded to the shaft......
PostPosted: Tue Jul 18, 2017 4:36 am
Car Model*:
Keep hitting it with PB Blaster let it soak for a day or two and exercise it, then repeat. Sooner or later it will free up enough to move at which time give it a good flushing of the rust & crud, and a white grease lube should fix it.
PostPosted: Wed Jul 19, 2017 10:32 am
Car Model*: 75valiant custom
good advise. i had the same problem, and that's what it took!
PostPosted: Fri Jul 21, 2017 4:19 am
Car Model*:
Here in the Northeast this is a common problem. Not so bad these days as the new cars have much better door sealing.
