It is currently Fri Mar 29, 2024 3:24 am
 Post subject: torsion bars
PostPosted: Tue Aug 07, 2018 5:10 pm
I store a parts car at a friends. I can pay him to remove parts on the car for me.
The 78 Cordoba has a big block and likely has bigger bars than my 95# bars.
The bigger bars would likely be the #100 bars.
Is the difference worth spending $75 and some time to install?
 Post subject: Re: torsion bars
PostPosted: Tue Aug 07, 2018 6:05 pm
95# to 100# would not be worth changing, but I bet the difference is bigger than that.
Home of Slant6-powered fun machines
PostPosted: Tue Aug 07, 2018 6:35 pm
https://www.forabodiesonly.com/mopar/at ... 714994906/
I have the .940 bars,,,,, can get .960
PostPosted: Wed Aug 08, 2018 4:05 am
Maybe your friend can put a caliper on them before removing? I guess it's better than no change and it is possible you could notice a difference.
PostPosted: Wed Aug 08, 2018 4:52 am
A small diameter change makes a big difference.
The stiffness increase is to the 4th power.
A 1.1" diameter bar would be (1.1 / 1.0)^4 or 1.4641 times stiffer than a 1.0" bar
(if the 1.0" bar was 100lbs, the 1.1" would be 146lbs)
PostPosted: Wed Aug 08, 2018 5:26 am
Yep, well aware of the 4th power dependence. Thanks, Ed. In this case, it's a very small diam difference and he gets a 5% rate increase.
Users browsing this forum: No registered users and 23 guests
