Slant Six Forum https://slantsix.org/forum/ |
For Corners https://slantsix.org/forum/viewtopic.php?f=13&t=61063 |
Author: | Greg Ondayko [ Thu Apr 27, 2017 11:12 am ] |
Post subject: | For Corners |
Is this a recommended part for 64 Darts? https://www.summitracing.com/parts/aco- ... structions Are there better Options or is this one good? Greg |
Author: | SpaceFrank [ Thu Apr 27, 2017 1:18 pm ] |
Post subject: | |
There are better (and more expensive) options, but that's the one I have on my 64' Dart LeMons racer. The only real downsides to it are the crappy mounting brackets. I think Lou is the one I saw in an old thread talking about how to improve the mounting situation. |
Author: | sandy in BC [ Thu Apr 27, 2017 1:19 pm ] |
Post subject: | |
That looks the same as the others. You will need to re engineer the K mounts, ( 2 pieces of angle) |
Author: | Greg Ondayko [ Thu Apr 27, 2017 1:51 pm ] |
Post subject: | |
Cool. I can re engineer things... thats easy. Yay welding😀😀 I bet i can get this thing Skookum asFrig in no time. I think lou will chime in as well. Greg |
Author: | Dart270 [ Thu Apr 27, 2017 2:21 pm ] |
Post subject: | |
That looks like the same mounting brackets and instructions that Addco had in 1989-1990 when I bought my first one for my 68 Dart, and again in 1998 when I bought the second one for the 64 Dart. Ugh. If you can spend that, then spend a few extra bucks, save 5-8 lbs (tubular), and get better mounting brackets. https://www.summitracing.com/parts/hel-55914 I just put one of these (for later Dart) on my 68. I still had to mess with the brackets a bit (weld/shim/adjust), but the hardware was so much better than the Addco stuff. Lou |
Author: | Greg Ondayko [ Thu Apr 27, 2017 3:14 pm ] |
Post subject: | |
So... ditch addco. And get hellwig? I like lighter. Greg |
Author: | emsvitil [ Thu Apr 27, 2017 5:27 pm ] |
Post subject: | |
Here's the addco fix: Addco just uses the bottom bolting (angle iron bolted to K-member,bottom A/R mount to angle iron). The fix is to also bolt at top as shown. |
Author: | The Moffittman [ Sat Jun 03, 2017 9:18 am ] |
Post subject: | |
Greg Ondayko wrote: I bet i can get this thing Skookum asFrig in no time.
Careful not to let the shmoo out of 'er, wa. |
Author: | sandy in BC [ Sat Jun 03, 2017 10:01 am ] |
Post subject: | |
Givver! |
Author: | The Moffittman [ Sat Jun 03, 2017 11:24 am ] |
Post subject: | |
Anybody else out there an AvE fan? Greg, I met you briefly at Mason Dixon. I was the tall guy who mistook you for a dude I was supposed to meet who called his car the "Ruster" also.. Turns out he didn't have it written down the side of his door. I didn't put two and two together until I saw your screen name later that night. |
Author: | Greg Ondayko [ Sun Jun 04, 2017 1:31 pm ] |
Post subject: | |
RELEASE THE SCHMOO. and We'll see if it chooches on the gland end. Greg |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
