It is currently Fri Apr 19, 2019 9:53 pm
 Post subject: Leaf spring eye ??
PostPosted: Sat Mar 17, 2018 7:34 am
Car Model*: 65 Valiant 2Dr Post
I have the springs off the race car (65 Valiant) and was going to install Poly bushing in everything. I pushed out the front rubber bushing and shell and went to install the Poly ones. However the Poly ones are 1 1/2" and the originals are 1 3/8" Anyone seen this? I thought that there were only 2 sizes. 1 1/2" and 2". That is all I am seeing available in the aluminum ones too. Any help appreciated.
Rick
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
 Post subject: Re: Leaf spring eye ??
PostPosted: Sat Mar 17, 2018 7:43 am
Car Model*:
Yep, I ran into the same thing when I put together my 66 Valiant. At that time there were no poly bushings in that size, available. I wound up using the rubber bushings from NAPA. Another option for race car only would be to have a set of metal bushings machined.
66 Valiant Signet 225 nitrous
PostPosted: Sat Mar 17, 2018 7:57 am
Car Model*: 1965 Plymouth Belvedere I
Can you chuck them in a drill or something to turn them down to fit? It doesn't seem like a huge difference to drop it down to the smaller size.
-Matt
http://www.MattmansMopars.com
Strive for Excellence, not Perfection.
PostPosted: Sat Mar 17, 2018 9:20 am
I may try that. Thanks Charlie, I thought I was able to read my caliper!
Rick
PostPosted: Sat Mar 17, 2018 10:18 am
I just took them and spun them up against my belt grinder for a few minutes and they work fine. They also have a larger eye bolt so that is a plus too.
Rick
PostPosted: Sat Mar 17, 2018 12:31 pm
Car Model*:
You may have to drill out the hangers...
PostPosted: Sat Mar 17, 2018 4:51 pm
Yeah, they fit the eye in the spring but needed drilled out for my hanger to fit through. The upper end of my hanger has a larger OD (1" I think) so the poly ones I have will not work. I have the tube through the frame that comes with the Mopar spring relocation kits. I will just reuse my rubber in that location unless I can find the right size poly's.
PostPosted: Tue Jun 05, 2018 8:49 am
Car Model*: '65 Valiant 170 T5
Since it is race car why not make or have some aluminum bushings made to use some of these: https://www.mcmaster.com/#plastic-bushings/=1d5j7rb on a tube that the bolt passes through?
Thom
Cross-threaded is tighter than Lock-tite
PostPosted: Tue Jun 05, 2018 10:35 am
Car Model*:
I turned down a set once in a lathe for that spring eye size. Sounds like you figgered it out!
"You mean you still have a Slant 6 in that thing?"
cron
