Slant Six Forum https://slantsix.org/forum/ |
Rear Brake Wheel Cylinders https://slantsix.org/forum/viewtopic.php?f=13&t=62722 |
Author: | jkotis [ Thu Aug 16, 2018 8:07 pm ] |
Post subject: | Rear Brake Wheel Cylinders |
I need to replace the rear brake wheel cylinders on my 1986 Dodge D150. The shop manual calls for 15/16" cylinder bores. I ordered some new wheel cylinders that are 7/8" from Rock Auto that were supposed to be for my truck. Can I use these wheel cylinders are should I order some 15/16" cylinder bore wheel cylinders? |
Author: | SpaceFrank [ Fri Aug 17, 2018 2:40 pm ] |
Post subject: | Re: Rear Brake Wheel Cylinders |
Depends. Did your truck lock up the rear wheels under hard braking with the 15/16" rear wheel cylinders before? Smaller diameter on the rear cylinders will mean less braking force on the rear shoes. This can actually be a good thing if the rear wheels had a tendency to lock up first, like a lot of Chrysler passenger cars. No idea if this applies to your truck, though. Things could also change loaded vs. unloaded. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
