It is currently Mon Dec 10, 2018 11:45 pm
 Post subject: '65 Valiant 2 door
PostPosted: Thu Nov 22, 2018 8:29 am
Car Model*: '65 Valiant 170 T5
Checking interest in this car as I'm losing mine.
This is a CA car, but there is some rust. Quarter sized hole in pass door low/front, windshield channel driver's lower corner area, base of driver's side A pillar in the gutter (dark spot in pic just fwd of the door mirror). Pics of these don't exist, but can be provided on request. With the removal of the four 30+ lbs each cop car wheels from the trunk the rake of the car has improved considerably since this pic was taken:
The "list" as I recall it:
Valley Head Service rebuilt Slant 6, balanced, mild EFI-compatible cam, pump fuel
Holley 2 bbl on Clifford intake
Cable throttle
90A Bosch alternator (ammeter by-passed)
GM HEI ignition
Rebuilt copper-brass radiator
All mandrel bend exhaust system
Borg-Warner T-5 5 Speed trans
Centerforce Clutch
Inertia Ring removed from flywheel
Hydraulic clutch system
3.73 rear axle
New drive-shaft
Wilwood Dyna-Pro front calipers, AR Eng. Caliper brackets, OEM rotors on disc spindles
Aluminum dual circuit m/c with adjustable proportioning valve
QA1 UCA's
Boxed & rebuilt LCA's
Firm Feel HD Tie-rods
New ball-joints and strut-rod bushings
Rebuilt steering box w/ fast ratio
New Idler Arm
Recent alignment
Bilstein shocks F/R
New fuel tank, electric fuel pump, by-pass FPR
Reupholstered front seat w/ 'bucket' contour in driver's position
H4 headlights
Trunk mounted battery
Build thread: viewtopic.php?f=12&t=49591
Price: $6k OBO - consideration will be given to a slant enthusiast.
The TBI and various other parts that I've acquired or made for the EFI conversion & front sway-bar can be included in the sale. The wood steering wheel and it's adapter in the build thread is NOT included. I am working on a suitable wood wheel replacement.
Thom
Cross-threaded is tighter than Lock-tite
 Post subject: Re: '65 Valiant 2 door
PostPosted: Thu Nov 29, 2018 4:59 pm
Car Model*:
Man If this car came along about 4 years ago it would be sold to me.
Good luck with the sale.
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
