It is currently Mon Dec 16, 2019 2:48 am
 Post subject: Carter bbd idle circuit
PostPosted: Tue Aug 13, 2019 4:17 pm
Car Model*:
PostPosted: Tue Aug 13, 2019 4:18 pm
Car Model*:
PostPosted: Tue Aug 13, 2019 4:21 pm
Car Model*:
PostPosted: Tue Aug 13, 2019 4:25 pm
Car Model*:
Carter stopped giving the part sizes, last year 1969. After that measurement with drill bits is needed to tell size.
PostPosted: Tue Aug 13, 2019 4:31 pm
Car Model*:
idle bleed in bodyImage
PostPosted: Tue Aug 13, 2019 4:34 pm
Car Model*:
PostPosted: Tue Aug 13, 2019 4:37 pm
Car Model*:
checked early air bleed and later solid fuel carbs. That hole all ways .0472
PostPosted: Tue Aug 13, 2019 4:41 pm
Car Model*:
venturi screwImage
PostPosted: Tue Aug 13, 2019 4:58 pm
Car Model*:
They all look the same, they are not. Different sizes of steel bushings pressed into hollow steel screw, the idle down channel. Blue is idle air bleed, carter called the first air bleed the bypass. Black is fuel entry, Yellow is idle Economiser, some times called idle channel restriction. in cluster screw acts like a main jet for idle circuit. Red is where stamped number is in line with dots. The econ bushing can be cleaned or size checked from bottom. Do not go past fuel entry holes . Same for top air bleed,check from top. Bushings can be different sizes.
PostPosted: Tue Aug 13, 2019 5:14 pm
Car Model*:
https://www.gfii.com/images/Greenfield_ ... alents.pdf
PostPosted: Tue Aug 13, 2019 5:28 pm
Car Model*:
PostPosted: Tue Aug 13, 2019 5:42 pm
Car Model*:
Recent testing shows that different venturi screws can make a difference. For example screw with .067 air bleed and .055 econ. restriction replaced with[ common to slant six], screw with .063 air bleed ,richer and bigger econ. restriction, .059 more mixture down stream. Seems to make things better.
PostPosted: Tue Aug 13, 2019 9:22 pm
Car Model*: 82 Ramcharger, 76 D100
This is great info!
PostPosted: Mon Sep 02, 2019 12:32 pm
Car Model*:
PostPosted: Mon Sep 02, 2019 12:35 pm
Car Model*:
Amc jeep specsImage
