Slant Six Forum https://slantsix.org/forum/ |
Dist hold down https://slantsix.org/forum/viewtopic.php?f=19&t=54366 |
Page 1 of 2 |
Author: | Reed [ Sun Jan 19, 2014 10:33 am ] |
Post subject: | |
The bracket on the left is the older style that offered a limited range of adjustment. There were two slots for adjustment- the one on the block that you commonly use and a much harder to get at one under the body of the distributor. The one on the right is the "modern" hold down that came into use in the late 70s/early 80s. The part you are holding is the "ring" that was bolts onto the bottom of the distributor body. There was also a "claw" that bolted to the block and put pressure on the "ring" and held the distributor in place. The "claw" hold down offered near 360 degrees of adjustability and was must easier to work with if you were timing an engine from scratch. Plus, it is nearly identical to the v-8 distributor hold downs so the uninformed v-8 guys wouldn't get confused when they tried to work on a slant six. The claw version is much more desirable, provided you have the matching ring. The ring is a slant six distributor only piece. Either system can be used on any slant six, provided you have the complete system. THe older system has the virtue of being a single piece and much more common. The newer system is easier to use and is more adjustable, but has two pieces and is harder to find complete. Someone should make a pattern of the ring and claw and sell some reproduction pieces. |
Author: | 1930 [ Sun Jan 19, 2014 11:49 am ] |
Post subject: | |
Hey thanks, anytime you want a pattern just ask |
Author: | Reed [ Sun Jan 19, 2014 12:50 pm ] |
Post subject: | |
Nah, I've already got at least one extra set. Thanks for the offer though. |
Author: | DusterIdiot [ Sun Jan 19, 2014 1:14 pm ] |
Post subject: | Update... |
Quote: The bracket on the left is the older style that offered a limited range of adjustment. There were two slots for adjustment- the one on the block that you commonly use and a much harder to get at one under the body of the distributor.
The bracket on the left is common from 1960-1978 model years...it also came in some variations of stampings with more or less slot for the block adjustment...the Ring and Clamp can be found from the 1979 model year up to the end in 1987... As Reed stated the claw and ring are much more desired as you don't have to use a distributor wrench to get more adjustment when dialing more initial timing...With the advent of 80's van's and trucks being more common now in junkyards and the junk monkey pulling the dizzy and tossing the claw...it makes getting the claw the harder peice to find (it is not the same as the small block or big block claws...so they can't be modified to get them to clamp right or fit the ring...)... I have about 20 rings and no claws...the problem with making the pattern is the claw is made of stamped and tempered steel...so even though we could laser cut a set of 12 gauge claws...the cost for that and getting them heated and quenched kind of kills the deal for most do it youselfers...the softer steel will just wear away on the ring until you loose your timing one day.... -D.Idiot |
Author: | Charrlie_S [ Tue Jan 21, 2014 4:14 am ] |
Post subject: | |
Personally, I don't like the Claw type on the early engine. There is no boss on the block for the back end of the claw to seat against. |
Author: | DusterIdiot [ Tue Jan 21, 2014 5:31 am ] |
Post subject: | Interesting... |
Quote: Personally, I don't like the Claw type on the early engine. There is no boss on the block for the back end of the claw to seat against.
Good to know, how early is early? One of my hi-comp blocks is a 1963 truck block and it worked with the claw just like my 67 and 70's blocks. -D.Idiot |
Author: | Charrlie_S [ Tue Jan 21, 2014 7:09 am ] |
Post subject: | Re: Interesting... |
DusterIdiot wrote: Quote: Personally, I don't like the Claw type on the early engine. There is no boss on the block for the back end of the claw to seat against. Good to know, how early is early? One of my hi-comp blocks is a 1963 truck block and it worked with the claw just like my 67 and 70's blocks. -D.Idiot Oh, it might work, but I was concerned it would not clamp tight enough, without that "boss", to support the rear of the clamp. Running nitrous, I don't need the distributer turning on its own. I don't know what year all my blocks are, but of 12 of them, none have the boss. I should have a cast crank block somewhere, I will try to find it, and look. |
Author: | Danarchy [ Tue Jan 21, 2014 12:49 pm ] |
Post subject: | |
Quote: I have about 20 rings and no claws..
D.I.- PM me if you are able to part with one of those rings? I could use one! -Thanks Dan |
Author: | beto_valiant64 [ Wed May 29, 2019 4:16 pm ] |
Post subject: | Re: |
Reed wrote: The bracket on the left is the older style that offered a limited range of adjustment. There were two slots for adjustment- the one on the block that you commonly use and a much harder to get at one under the body of the distributor.
Author: | Badvert65 [ Wed May 29, 2019 6:16 pm ] |
Post subject: | Re: Dist hold down |
The "older" style works on any slant block. The "newer" style really only works on blocks cast specifically for the claw style. Also, the slant six distributor claw is unique to the slant six, nothing else really works. I have two engines, one of each style. It might be possible to make some other clamp style work on earlier blocks, but it won't be anything that directly bolts on. I prefer the claw style mount and would like to make something 'claw like' work on the earlier blocks. |
Author: | Reed [ Wed May 29, 2019 6:33 pm ] |
Badvert65 wrote: The "older" style works on any slant block. The "newer" style really only works on blocks cast specifically for the claw style. I dispute this. I have used the "claw" on pre-76 engines with zero problems. I have a 76 engine, an 83 engine, and an unknown year engine in my garage. I will look at the distributor mounting area and see if there is any difference. I don't think there is. |
Author: | Badvert65 [ Wed May 29, 2019 7:03 pm ] |
This pic (1979 block) shows the "ledge" that gives the claw leverage for clamping. Without something for the lip of the claw to lever against, it just bolts flat down onto the flat machined block surface (earlier style blocks) and the lip just hangs over the edge without pushing against anything. It will still give some clamping action on earlier blocks, but not nearly as much as on the later blocks. This pic shows an aluminum claw I made from a piece of aluminum angle. It does the job quite well, but was a pain to make. Attachment: This pic is of the factory claw from my 1979 block (I drilled the extra holes in it). Attachment: Attachment:
Author: | Reed [ Wed May 29, 2019 7:36 pm ] |
Hmmmm. I have a hard time believing the block was modified just for the hold down, but those are good pictures. I will investigate further. |
Author: | Badvert65 [ Thu May 30, 2019 4:39 am ] |
I am just showing pics of what I have found out. I have no idea when the claw style mount started, but I believe it was mid to late 70's. The block is indeed different for the claw mount, but I am not saying the claw will not work on earlier blocks, I am saying it doesn't work nearly as well on the blocks without the cast in ledge (or at least a wide enough machined area for the lip of the claw to get leverage). I can post pics later of the claw on a 73 block (without the ledge). jus sayin |
Page 1 of 2 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
