It is currently Sat Mar 28, 2020 1:50 am
 Post subject: Slant 6 info.
PostPosted: Sun Mar 18, 2018 7:13 am
Car Model*: 1967 Dodge Dart 270
Hey guys, I'm new here and just picked up a 67 Dodge Dart with the slant 6. I would like to beef the motor up a little bit with out have to take the motor out yet. Kind of new to the slant 6s any info would be great!
 Post subject: Re: Slant 6 info.
PostPosted: Sun Mar 18, 2018 6:13 pm
Car Model*: 1972 Dodge Colt
welcome!
Tell us what you want to do with the car.
Lots of folks have ideas on what to do with your combo.
Engine new or recent rebuild?
Auto, stick,NA, turbo, blown, budget?
PostPosted: Sun Mar 18, 2018 6:53 pm
Car Model*:
Holding off on answering this until a moderator moves it to the correct forum. This is not the place for technical questions.
PostPosted: Mon Mar 19, 2018 7:51 am
hyper_pak wrote:
welcome!
Whats recomended for intake, headers, possibly a 4 barrel carb but I know if I put the 4 barrel on I'm going to have to change the cam shaft.
PostPosted: Thu Mar 22, 2018 12:32 pm
Car Model*:
First things first. Save yourself some time and a lot of money and headache. See what kind of shape the drive train is in before you spend the first dime. Do a compression test. Check the valve lash. See if the timing chain is worn out. If all that is good, then figure out howyou plan on using the car. Much advice will flow forth on these pages if we know what you want the car to do. Drag strip occasionally but a daily driver? Daily driver but more power than stock? Is your dream to make the most of every gallon of gas and have it last a million miles?
PostPosted: Thu Mar 22, 2018 3:17 pm
Car Model*:
Welcome on the board. As soon as you can, get the three books listed in this thread. Tune-up parts and technique suggestions are in this post; you'll want to go through and make sure all that maintenance/tune-up type stuff is done properly to see how the engine really runs before you start thinking of upgrades.
Once you've done that (and checked the basic health of the engine with a compression test and a quick check for timing chain slack as described here), then would come time to start thinking about upgrades. There's a lot of "low-hanging fruit" (upgrades that can be done with relatively low effort and expense); probably the first items on that list are the Fuel line mod and the HEI upgrade.
Also keep in mind that the engine bay's not the only place you should be looking at/thinking about upgrades; see here.
