Slant Six Forum https://slantsix.org/forum/ |
holley 390 inlet leak https://slantsix.org/forum/viewtopic.php?f=19&t=62284 |
Author: | Dizzydean [ Tue May 01, 2018 9:46 pm ] |
Post subject: | holley 390 inlet leak |
I'm having troubles with a leak at the banjo inlet on my holley 390. I did a gasket, needle valves, adjusted floats, power valve, a basic overhaul due to a leak at the secondary bowl at the feed tube. That leak is gone but now I cannot get the inlet to quit leaking. The steel/rubber pieces weren't thick enough to seal it and ive tried an oil pan copper washer with no luck in fact it was worse. Any ideas?? like to get my car to run longer than 3-4 seconds. I'm open to using a barb fitting but don't see one that would work. Thanks for any help/advice. |
Author: | DusterIdiot [ Wed May 02, 2018 4:32 pm ] |
Post subject: | Re: holley 390 inlet leak |
Something is wrong with the assembly if the standard gasket/washers didn't work. You will probably need a new banjo fitting and screw...if you don't want a new one, they are standard on all other Holley 4150/60's and most 2300 2 barrels... |
Author: | Dizzydean [ Thu May 17, 2018 9:01 pm ] |
Took the fitting off a spare 600 and it worked perfect with the new gaskets. Now if I could just figure a way to turn the carb 90* on the Clifford intake... |
Author: | Charrlie_S [ Fri May 18, 2018 3:57 am ] |
If you "elongate" the mounting holes in the Clifford adapter plate, you can rotate it 90 degrees. |
Author: | Rick Covalt [ Fri May 18, 2018 8:55 am ] |
I thought some cliffords were a square pattern and could just be rotated. |
Author: | ntsqd [ Tue Jun 05, 2018 1:16 pm ] |
Rick Covalt wrote: I thought some cliffords were a square pattern and could just be rotated. My Holley 2bbl is mounted with the shaft parallel to the crank-shaft on a Clifford intake. The Clifford 2bbl adapter to the intake bolt pattern does look square, but I never measured it because it worked how I thought it should be set-up. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
