It is currently Tue Apr 23, 2024 11:02 pm
PostPosted: Mon Aug 12, 2019 3:57 pm
I'm in the process of cleaning out the block (225) and replacing the water pump and noticed this cavity in the block (pointing the screw driver at it) is this a water passage filled with crud or just part of the casting? I see that its not connected with the impeller area or passage below but just wanted to double check. I didn't see this on another photo of a slant block. I think the block is a 68 or 69
PostPosted: Wed Aug 14, 2019 8:28 am
Normal and found on many SL6 blocks.
The correct water pump gasket seals-off that "cored-out" area, to prevent crud build-up but a bead of sealer will also do the job.
PostPosted: Wed Aug 14, 2019 10:11 am
Thanks DD! This is m first slant but its been a lot of fun learning about these motors on this site.
Users browsing this forum: No registered users and 39 guests
