It is currently Wed Apr 24, 2024 4:15 pm
PostPosted: Mon May 06, 2019 8:16 pm
Car Model: 1971 Dodge Dart 225 slant 6
Okay guys and girls since wiseco doesn’t make 60 over pistons for the 225 I’m looking at k/b cast aluminum pistons stock cp height and will be using the 7 inch rod on the 225 has anyone else tried that combo if so how’s it work? The engine has a ported and polished head with a 3 angle valve job, a Oregon 470/470 lift cam, polished crank, 4bbl intake and a header will those pistons last when being beat on??? And if not who makes good 60 over pistons?
PostPosted: Mon May 06, 2019 10:30 pm
If it's a stock compression height piston you will be roughly .120" up out of the hole.
7" rods use KB 2.2 liter pistons. They end up roughly .020" down with an uncut deck.
PostPosted: Tue May 07, 2019 5:58 am
Is the engine already bored? If not Wiseco has .045 available. Maybe .084, you would have to call.
https://www.campbellenterprises.com/sla ... istons.php
66 Valiant Signet 225 nitrous
PostPosted: Tue May 07, 2019 8:32 am
SL6 Racer
Wiseco can make a "custom" piston 60 over but it's really expensive.
PostPosted: Tue May 07, 2019 8:40 am
Car Model: 64 Valiant
No, cast pistons will last if you beat on them. There are many options for pistons such as RaceTech, Venolia and a few others that make reasonable custom forged pistons.
PostPosted: Tue May 07, 2019 1:41 pm
Tell us more of what your plans are with the engine. Is is a race motor, street strip.....etc.. Plenty of Slant 6 engines have been run hard with the stock 225 rods and stock pistons.
PostPosted: Tue May 07, 2019 3:52 pm
Going to be a street/strip engine and it’s already been bored out 60 over so it’s now 3.460 does somebody make a 2.2 turbo piston that size that I could use the 7 inch rods with and if so what would the compression be I’m looking for around 10-1
PostPosted: Wed May 08, 2019 7:18 am
I really need help guys
PostPosted: Wed May 08, 2019 1:05 pm
here is a link to the dished KB 268 pistons
https://uempistons.com/series-2621-kb-a ... kb268.html
the KB 239 is similar but is a flat top with valve reliefs
both the 268 and the 239 have been used with the long rod in slant six builds
more info is available at the KB web site, the pistons and rings are available from KB or other
sources like Summitt, Jeggs,,,,
https://uempistons.com/c-43-kb-automoti ... hyper.html
You will need to see if there is a size that matches to the ,060 over block,,
I doubt it as the 268 and 239 are metric pistons,, so it may just another trip to the machine shop.
PostPosted: Wed May 08, 2019 1:14 pm
By turbo I meant the pistons made for a Chrysler 2.2 turbo I’m not putting a turbo on this motor
PostPosted: Wed May 08, 2019 2:51 pm
A stock 2.2 piston is 87.5mm (3.445) and a .5mm oversize is commonly available.
88mm = 3.46457 or basically, a 065 oversize.
You will have to hone a few more thousands out of the bores to get the correct fit but that is pretty straight forward.
PostPosted: Wed May 08, 2019 7:42 pm
Thank you so much for the input now my final question on this is can I run the 7 inch rods on 2.2 pistons and not stick out over the block
PostPosted: Thu May 09, 2019 2:26 am
Depends on if and how much your block has already been decked.
PostPosted: Thu May 09, 2019 9:05 am
The block has not been decked
PostPosted: Thu May 09, 2019 9:37 am
not been decked
you will be good, just have the pistons in hand before doing the final bore sizing
Users browsing this forum: No registered users and 52 guests
cron
