Slant Six Forum https://slantsix.org/forum/ |
water pump housing on block https://slantsix.org/forum/viewtopic.php?f=19&t=63933 |
Author: | Doctor Dodge [ Wed Aug 14, 2019 8:28 am ] |
Post subject: | Re: water pump housing on block |
Normal and found on many SL6 blocks. The correct water pump gasket seals-off that "cored-out" area, to prevent crud build-up but a bead of sealer will also do the job. DD |
Author: | Thebearded1 [ Wed Aug 14, 2019 10:11 am ] |
Thanks DD! This is m first slant but its been a lot of fun learning about these motors on this site. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
