Slant Six Forum https://slantsix.org/forum/ |
Throttle return spring size https://slantsix.org/forum/viewtopic.php?f=19&t=65431 |
Author: | jayman62 [ Fri Oct 16, 2020 11:46 am ] | ||
Post subject: | Throttle return spring size | ||
Please see attached diagram, for reference I have a 66 Dart GT 225, auto, Holley 1920. Throttle return spring is missing, anyone know a part number or size, weight, of spring?
Author: | Greg Ondayko [ Fri Oct 16, 2020 3:01 pm ] |
Post subject: | Re: Throttle return spring size |
Dont know but I can measure the one on my 64 and post it for ya.. Its's the stock parts there for now. Greg |
Author: | plymouthcranbrook [ Sat Oct 17, 2020 8:20 pm ] |
I bought a set of 6 assorted springs on Amazon and just messed with it till I found one that fit the needs on my Volare. |
Author: | jayman62 [ Fri Oct 30, 2020 7:14 am ] |
Greg Ondayko wrote: Dont know but I can measure the one on my 64 and post it for ya.. Its's the stock parts there for now. Greg Hi Greg, I hate to be a pain but were you able to measure your spring? Thanks. |
Author: | Greg Ondayko [ Fri Oct 30, 2020 10:06 am ] |
jayman62 wrote: Greg Ondayko wrote: Dont know but I can measure the one on my 64 and post it for ya.. Its's the stock parts there for now. Greg Hi Greg, I hate to be a pain but were you able to measure your spring? Thanks. Ooh That car is home now.. I totally forgot about it, I will get it tonite. Greg |
Author: | jayman62 [ Fri Oct 30, 2020 10:53 am ] |
Thanks Greg, side question, what size rear wheels are they that you can tuck them into the rear wells? |
Author: | Greg Ondayko [ Fri Oct 30, 2020 11:30 am ] |
jayman62 wrote: Thanks Greg, side question, what size rear wheels are they that you can tuck them into the rear wells? 17 X 8's at +52 Offset with a 69 B body rear, I am sure with the proper "A" or "FJM" Body Rear end and proper offset you can fit 17 X 9's without cutting.... Bigger than that then you are into mini tub territory. My + 52 MM 17X 8's ave about an inch clearance to the centerline of the car's body, but Do rub the outer wheel house in full compression. ↓↓↓↓Read about the maladies of all that here↓↓↓↓ viewtopic.php?f=42&t=60536&start=60 Greg |
Author: | Greg Ondayko [ Fri Oct 30, 2020 6:45 pm ] |
upon inspection I think my spring was broke and butchered and cobbled sometime before I owned the car.. but it still works properly as is. 20201030_194525 by Hyperpack, on Flickr 20201030_194644 by Hyperpack, on Flickr 20201030_194520 by Hyperpack, on Flickr 20201030_194450 by Hyperpack, on Flickr Greg |
Author: | jayman62 [ Sat Oct 31, 2020 4:12 pm ] |
GREAT! Thank you Greg ad thanks for the wheel discussion!!! Jay |
Author: | Greg Ondayko [ Sun Nov 01, 2020 1:42 pm ] |
jayman62 wrote: GREAT! Thank you Greg ad thanks for the wheel discussion!!! Jay No problem.. you need to stop out this way sometime and I will take ya for a ride in the dart. Greg |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
