It is currently Fri Apr 10, 2020 12:39 pm
PostPosted: Tue Mar 24, 2020 7:12 pm
Online
Car Model*:
Whaddya guys use when you are assembling the hose ends on to the AN Type Hose?
Some of the new ones I have been working with are a real bear to the point that they are defoeming my AN wrench..
Currently Working the -10 size / Diameter... I am not sure if that makes a difference or not.
I $pent up for the priĀ¢er hose this time too... Maybe the Better hose just has a wee bit smaller I.D. and Larger O.D. which will cause the problems that I am having when trying to spin the hose ends on.
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
PostPosted: Wed Mar 25, 2020 7:57 am
Car Model*: 68 Valiant
I use WD-40.
PostPosted: Wed Mar 25, 2020 4:21 pm
Online
Car Model*:
Thanks Dennis. I will try that next time and see if its better at all.
Greg Ondayko
PostPosted: Thu Mar 26, 2020 4:38 am
Car Model*:
WD-40
I have also used red grease.
A vise with aluminum jaw inserts helps
and throw away the an wrench when putting the hoses together.
Also always put a little lube on the threads even when putting the hose in place on the engine
the aluminum on aluminum threads can gull up easily.
Will
PostPosted: Thu Mar 26, 2020 6:26 am
Car Model*: 65 Valiant 2Dr Post
I put the fitting in my vise using a leather glove as a cushion. And a little Vaseline on fitting.
2 Mopars come with Spark plug tubes. One is a highly refined, world class, racing machine. The other is a 426 CI. boat anchor!
PostPosted: Fri Mar 27, 2020 2:05 pm
I use Royal Purple synthetic engine assembly lube when I assemble rubber lined AN hoses. It works well and I already have it sitting around.
I hardly do it anymore as I've switched to the braided PTFE hose. It's far lighter and easier to work with when you use the thread-assemble fittings. But even better is when you use it with the crimped fittings which are more compact and can never, ever leak or come loose. XRP HP-79 is one such hose.
On my soapbox, XRP and Earl's are the only two companies left who make fittings in the USA (to say, the only non-Chinese country making fittings).
