Slant Six Forum https://slantsix.org/forum/ |
Tubes in slicks... https://slantsix.org/forum/viewtopic.php?f=2&t=62298 |
Author: | Rob Simmons [ Fri May 04, 2018 6:02 am ] |
Post subject: | Tubes in slicks... |
I'm sure neither the Challenger or Duster have tubes currently... Ordering the M/T slicks for the Duster (yes, my first time ever buying slicks ) and Summit sez I gotta have 'em! Y'all runnin' tubes in yer slicks...? |
Author: | Greg Ondayko [ Fri May 04, 2018 8:49 am ] |
Post subject: | Re: Tubes in slicks... |
You can run them. I don't. Pressures may be more consistent, at the expense of more rotating weight. Greg |
Author: | Badvert65 [ Fri May 04, 2018 9:39 am ] |
Aren't you supposed to put talcum powder in the tire for the slick and tube lubrication. At least with wrinkle wall slicks, I believe. -Matt |
Author: | Rob Simmons [ Fri May 04, 2018 11:14 am ] |
I have also heard that people use either baby powder or dish soap when they don't use tubes in order to help from leak down. |
Author: | Charrlie_S [ Fri May 04, 2018 11:34 am ] |
My 23x10x13 inch slicks, leak thru the side wall, and there are no tubes available for them. I used Dawn dish soap on the inside. It helped, but didn't cure the problem. At least they don't go flat overnight. My 7x26x15 have tubes. Use talcum/baby powder, when using tubes. It lets the tube and tire slide, and prevents the tube from getting pinched. |
Author: | slantzilla [ Fri May 04, 2018 4:00 pm ] |
Heavy high horsepower cars and stick cars like tubes. That pretty much leaves most of us out. |
Author: | Rick Covalt [ Fri May 04, 2018 4:11 pm ] |
Quote: stick cars like tubes Interesting? But why is that? |
Author: | slantzilla [ Fri May 04, 2018 6:16 pm ] |
Because they beat the crap out of the sidewalls, especially if it's a heavy car. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
