Slant Six Forum https://slantsix.org/forum/ |
So what are you bringin to the races??? https://slantsix.org/forum/viewtopic.php?f=2&t=62764 |
Page 1 of 3 |
Author: | Rick Covalt [ Mon Aug 27, 2018 6:32 pm ] |
Post subject: | So what are you bringin to the races??? |
Just thought I ask what all you are bringing to Clay City to the races. Since many are drive long distances and want to enjoy the whole weekend, I will be bringing some spare parts, tools etc. along just in case. So Here is my list. Tell me what else I need and what I may be forgetting. Normal hand tools are wrenches, screwdrivers...etc that we all will have. Here is my list to get us started. Normal Hand tools Tow strap- Hope we don't need this! Compression tester Tire gauge Small aluminum jack Small stands Drain pan Fluids - Water / Oil / Trans. fluid Race gas Cleaners- Brake / Carb Rags / towels Small generator Fan - To keep me cool! Battery charger Canopy / Chairs Head gasket Intake gasket Valve cover Gasket Carb gasket Water pump & gasket Oil pump & gasket ( probably need a cam!) Alternator Spark plugs Carb. jets and rods Coil HEI modules Spare electric Fan Electrical- Wires,connectors, relays, fuses |
Author: | Team Green [ Mon Aug 27, 2018 7:05 pm ] |
Post subject: | Re: So what are you bringin to the races??? |
What about the kitchen sink? What an impressive list. I thought we packed some stuff but nothing like you bring! Good job! Mark |
Author: | Greg Ondayko [ Mon Aug 27, 2018 7:09 pm ] |
Rick.. You forgot some important stuff. Tow vehicle Race car driver Race car Trailer Greg |
Author: | emsvitil [ Mon Aug 27, 2018 7:13 pm ] |
Don't forget the Toilet Paper |
Author: | sandy in BC [ Mon Aug 27, 2018 8:22 pm ] |
1/4 oz hash//////>M> |
Author: | slantzilla [ Mon Aug 27, 2018 10:42 pm ] |
A grill and a case of fresh brats. Bunch of stuff to sell. Hopefully I remember my helmet and long pants. Generator and battery charger. Yes, I'm going to be "that guy" with the noisy ass generator. General assortment of tools and parts. Someone to turn the main switch on when I belt myself in the car with it off. |
Author: | Rick Covalt [ Tue Aug 28, 2018 3:21 am ] |
One thing I did forget was the can of "red light" preventer! |
Author: | wvenable [ Tue Aug 28, 2018 4:05 am ] |
I am bringin my ruggedly handsome good looks and some cookies! |
Author: | Charrlie_S [ Tue Aug 28, 2018 5:25 am ] |
As little as possible. Towing with my slant six D-100. Bringing parts for sale/delivery. Hopefully, if I do need something, the rest of you will be able to help me. |
Author: | Rob Simmons [ Tue Aug 28, 2018 5:32 am ] |
I usually make a mad thrash through the garage the day before or the morning of leaving and just grab whatever looks helpful. Some day I might get organized and actually prepare ahead of time for this stuff... or not... (This time I do have a couple things I know I must bring: At least one trophy and a wad of cash! ) |
Author: | burgmopar [ Tue Aug 28, 2018 5:59 am ] |
Missing from your list: Timing light Air compressor Torque wrench Breaker bar Fuel filter Fuel pump Ballast resistors |
Author: | Dart270 [ Tue Aug 28, 2018 8:12 am ] |
Pretty comprehensive, Rick. I usually bring some parts, along with toolbox, timing light, comp tester... I have a "race box" Rubbermaid tote that has a rotating group of parts and specialty tools. It always changes and sometime I have what I need, sometimes not. LeMons races usually deplete several things and I sometimes do not remember to replenish them. Partial list of usual parts: Belt(s) and generic hoses (vac, fuel, htr, flex radiator hose) Extra dist (electronic, locked or recurved) and another extra dist gear Misc bolts/nuts/washers Breaker bar and hand crank "spinner" for wheel r'n'r Spare pair of wheels/tires (often) Extra WBO2 sensor (sometimes) Oil, trans fluid, coolant/water, sometimes brake fluid, -20F WW fluid if racing turbo car (boost juice) Stuff to wash car I could go on... This time I will have the B350 van, so I'll have a double mattress/futon and cushy sleeping stuff. Often I bring a tent+sleeping bag+pads. Lou |
Author: | Greg Ondayko [ Tue Aug 28, 2018 5:29 pm ] |
slantzilla wrote: Someone to turn the main switch on when I belt myself in the car with it off. Pheww... I am glad someone thought of that. Greg |
Author: | slantzilla [ Tue Aug 28, 2018 6:26 pm ] |
Greg Ondayko wrote: slantzilla wrote: Someone to turn the main switch on when I belt myself in the car with it off. Pheww... I am glad someone thought of that. Greg And when I cinch the belts so tight I can't reach the door bar to close it. |
Author: | Badvert65 [ Wed Aug 29, 2018 5:00 am ] |
If it is more than an hour drive (one way) I like to bring extra stuff. In addition to Rick's list, I like to keep the following: extra lug nuts/washers thermostat/gasket gas cap and radiator cap hose clamps Octane boost wd40 small tarp fan belt top & bottom radiator hose Duct tape electrical tape funnel cap/rotor one long plug wire safety wire oil pan drain plug spare hood pin clips gas tank/radiator repair putty one or two spark plug tubes/gaskets I don't bother with bigger stuff like water pump, oil pump, alternator, carb, etc. If anything like that would crap out, I'll make do or spectate. |
Page 1 of 3 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
