It is currently Fri May 03, 2024 9:55 pm
PostPosted: Thu Jun 04, 2009 6:05 am
I'm replacing the clutch, bearing, and housing (replacement kit). I forgot to mark where the old housing aligns with the flywheel as described in the repair manual. How can I assure that the new housing will be oriented correctly on the flywheel? Is this critical? :roll: Thanks!
John in Colorado
