It is currently Thu Apr 25, 2024 11:57 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
PostPosted: Tue Dec 29, 2009 3:05 pm
Site Admin
Red text is a link. left click on the text, and you will go to the information described.
Check the Articles section from the Home page first!
Here's a quick link to help you get there: Tech Articles
Transmission Articles
4 Speed Transmissions (by Doug Dutra)
Clutch Overview
904 Tansmission:
Identifying your transmission
Band Adjustment
904 shift point adjust
Pre-'64 auto trans filter retrofit
What V8 guts swap into a slant case?
Can you ID this 904 LU?
No kick downshaft on this LU 904
Hooking up the 904 to my electronic speedo?
How to disable the lockup feature on a lockup A-904 or A-727
Recommendation for floor shifter for 904
Repair of ring gear on 904
This is WHY I hate lock-up transmissions
Disection of a 1978 S/6 lock-up 904 trans
727 Transmission
904 to a 727
Trans swap (to a 727 from 904)
kickdown for 727
727 auto won't bolt back onto 225 /6
Adventures in kickdown (fabbing kickdown)
Confused...904 vs. 727 spline
MOPAR MANUAL TRANS (833, A-903, etc)
833 OD mainshaft fix tutorial
Slant 6 10" Performance Clutch Install 3-16-12
T5 TRANS
Brief t-5 install instructions.
Found a T-5 now off to the planning department
T-5 Swap Pieces?
T-5 Behind a Slant
Photo of T5 adapter and install
Doing the T-5 swap need advice
T5 Slanters Needed
T-5 from a 2000 V6 Mustang
Another 5 speed question
What 5 speed to a Slant
interesting trans swap option(Sandy in BC brief description of install)
What 5 speed would you use?
Users browsing this forum: No registered users and 42 guests
