It is currently Thu Apr 18, 2024 8:20 pm
 Post subject: 5 speed
PostPosted: Thu Oct 24, 2019 12:59 pm
What transmission came in a 1985 dodge d150 slant 6 manual 5 speed?
 Post subject: Re: 5 speed
PostPosted: Thu Oct 24, 2019 2:21 pm
It would be the A833 6 speed. 4 speeds forward, One reverse, and in Neutral you got Zero speed.
PostPosted: Thu Oct 24, 2019 2:39 pm
I don't think there was a factory 5 speed for this engine.. at least not here in us/ canada.
The early dakotas might have 5 speeds but no slant 6's in those.
PostPosted: Thu Oct 24, 2019 3:00 pm
A u-pull-it close to me list a 1985 D150 225 5 speed I would like to know what to look for and what it might be
PostPosted: Thu Oct 24, 2019 4:44 pm
I would believe the listing is incorrect.
Its an 833 od.
3 forward gears that end with a 1:1 ratio then one overdriven gear at say ~.73:1 -.68:1.
PostPosted: Thu Oct 24, 2019 5:00 pm
1986 was the last year of the A833
PostPosted: Thu Oct 24, 2019 5:01 pm
You can only tell by physically checking it, D-150's typically got the NP435 top loader because the D-150 got the HD suspension vs. the D-100... D-100 typically got 3 speeds in base models, and the A-833OD in later models... there are some mix match in 1985-1987 where I've seen D-150's with the A-833OD, but the owners wouldn't let me inspect the data tag for corroboration that it was a factory combination.
If you are dead set on a 5 speed, or T-5 upgrade, you can get a factory bellhousing for your vehicle, the transmission you want to convert to from the junkyard, and pay a local machinist with fabrication ability to make an adaptor plate for the rear of the bellhousing to mate it together.
Just sayin'...
Users browsing this forum: No registered users and 29 guests
