It is currently Mon Jun 18, 2018 2:40 am
 Post subject: bell housing removal
PostPosted: Sat Jul 22, 2017 5:36 pm
3 Deuce Webber
Car Model*: 1970 D100
Trying to remove the bell housing off of my 1970 slant six out of my d100 truck; I have all visible bolts removed, starter, tin pan, etc but it is stuck fast.
Read somewhere that perhaps some slant 6 trucks had an extra couple of bolts on the inside which I am suspecting I have.
if this is the case how the heck do I get at them? Do I have to remove the clutch and pressure plates to make room to get up inside the top of the bell housing?
 Post subject: Yep...
PostPosted: Sat Jul 22, 2017 5:51 pm
Car Model*:
If it's the 11" clutch low mount starter bell, then yes you have 3 bolts that can only be accessed after removing the pressure plate, disc, and flywheel....
PostPosted: Sat Jul 22, 2017 6:29 pm
3 Deuce Webber
Pulled the clutch and flywheel and I indeed have the 3 extra bolts inside.
Glad I didn't get too carried away with the dead blow!
PostPosted: Sat Jul 22, 2017 7:09 pm
Car Model*:
Those 3 bolts are outside the bell on that A904 and high mount starter manual transmission bells...
