It is currently Wed Apr 24, 2024 2:01 pm
 Post subject: flywheel
PostPosted: Fri Dec 01, 2017 3:46 pm
Found a 122 tooth flywheel at a local yard for my 833OD swap, but after bringing it home I measured the clutch pattern on the surface and it measures 9 1/4". I seem to remember that an OD 4 spd trans needs a 10" clutch. Is it a true 10" clutch or a 9 1/4" clutch.
Thanks
 Post subject: Re: flywheel
PostPosted: Sat Dec 02, 2017 6:10 pm
FYI. he has the correct flywheel. The 10" clutch is only 3/8" bigger on each side past the 9 1/4" clutch wear pattern. The disc almost touches the bolts when the disc is indexed on the flywheel.
D100 will be looking for the 10" clutch cover bolts since they are different than the 9 1/4" cover bolts which the Ford Mustang ARp bolts can be used... but not for the 10" cover.
PostPosted: Sat Dec 02, 2017 6:15 pm
DI, thank you so very much for all the help you have given me. Very much appreciated.
Users browsing this forum: No registered users and 40 guests
