Slant Six Forum https://slantsix.org/forum/ |
A833 OD transmission fluid https://slantsix.org/forum/viewtopic.php?f=20&t=62526 |
Author: | DadTruck [ Wed Jun 27, 2018 5:25 pm ] |
Post subject: | A833 OD transmission fluid |
just passing along what is working for me... when I re newed the 83 D150 back in 2010 I had the A833 tranny gone through by Brewers ATF was what I drained out of the tranny when I pulled it and ATF as specified by the FSM is what went back in. January of 2017 after 21642 miles I changed out the ATF for Redline MT-90 GL-4 fluid the transmission shifted OK with the ATF but I was looking for something better and the Redline MT-90 has good reports in several internet forums. This OD A833 just never shifted well with the MT-90. If I hurried the shift at all, I would get gear clash, especially from 2nd to 3rd. If I shifted slow, like move from first, wait a half second, and pull into second, shift from second, wait,,then push the shifter into third,,, it would shift ok,, felt like I was waiting on the syncro's to align the next gear. I tried improving the adjustment on the shift linkage,, made no difference. I drained out the MT-90 with 9000 miles on it ( yes I have 29630 miles on the D150, my how the miles fly by) and refilled the A833 case with Sta-Lube 85W90 GL-4 Gear Oil. This is what I was after, shifts real nice, the next gear just clicks in place. No waiting. I found the Sta-Lube at NAPA, was $35.00 a gallon, but well worth it. |
Author: | dirtyd100 [ Wed Jun 27, 2018 6:38 pm ] |
Post subject: | Re: A833 OD transmission fluid |
Good info, especially for me as I am just finishing up my 833od swap. Thanks |
Author: | halfafish [ Thu Jun 28, 2018 6:38 am ] |
Good to know, and thanks for sharing. I'll be installing the same tranny, also newly rebuilt, in the near future. |
Author: | Joshie225 [ Thu Jun 28, 2018 8:00 am ] |
DadTruck wrote: I drained out the MT-90 with 9000 miles on it ( yes I have 29630 miles on the D150, my how the miles fly by) and refilled the A833 case with Sta-Lube 85W90 GL-4 Gear Oil. This is what I was after, shifts real nice, the next gear just clicks in place. No waiting. I found the Sta-Lube at NAPA, was $35.00 a gallon, but well worth it. Odd. I had the opposite experience. Cheap GL-5 was good shifting, but RedLine MT-90 gave excellent shifting. This was with a standard A833 however. And it had never been overhauled. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
