It is currently Tue Apr 16, 2024 11:49 am
PostPosted: Wed Aug 01, 2018 6:26 am
Car Model: 1968 Barracuda - Fastback
Is it possible to tell if I can use a 1968 and newer torque converter by the transmission part number and build date? Or do I have to count the splines and measure the shaft?
I have an early '68 904 transmission (PK 2892027Y 2237 0651) and it would be optimal to use a '68 and newer converter - just wondering if it's as easy as reading the pan rail data. I can't image being that lucky, but thought I'd throw it out there.
The data indicates it's the correct (assumed original) transmission with an assembly date of September 12, 1967; and #651 off the assembly line as best I can decipher. The engine was cast in June with a final assembly in September 18, 1967.
Trans rail image here > https://www.instagram.com/p/Blv8GDbh4Pa/
-C
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Wed Aug 01, 2018 9:50 am
Did not find exact info on this in my torque flite stuff. Link to bulletins http://www.hamtramck-historical.com/196 ... ndex.shtml
Users browsing this forum: No registered users and 15 guests
