Slant Six Forum https://slantsix.org/forum/ |
4 speed linkage https://slantsix.org/forum/viewtopic.php?f=20&t=67447 |
Author: | Rick Covalt [ Wed Oct 04, 2023 6:53 am ] |
Post subject: | 4 speed linkage |
Has anyone on here fabricated your own linkages using rod ends? I’m thinking about making my own but I don’t want to reinvent the wheel. Or does anyone have a set of A body overdrive linkages. |
Author: | hyper_pak [ Wed Oct 04, 2023 7:41 am ] |
Post subject: | Re: 4 speed linkage |
Hey Rick, I was going to do that, but smaller rod ends are a little hard to find the right tubing. S&W might have what you need. |
Author: | Greg Ondayko [ Wed Oct 04, 2023 8:53 am ] |
It's probably better / more accurate to make your own as most of the factory rods can be quite worn. I bet you can get a new or nicely reconditioned set from brewer's. I try to tighten up the rods on my cars but they are wallered out and the nubs are too small and the holes are too big going on 50+ years old now. Greg |
Author: | halfafish [ Mon Oct 16, 2023 6:03 pm ] |
I have a set of 833OD shift rods that are going on my 66 when the time comes. If you need photos/measurements shoot me a PM. I can't get photos to post here no matter how hard I try... |
Author: | Rick Covalt [ Tue Oct 17, 2023 3:51 am ] |
Thanks, I decided just to make the one long rod that was not in too good of shape. I just have to weld an end on and get a shoulder bolt and I should be good. Eventually I will make a set of rod with rod ends on it, but this will get me going for now. |
Author: | hyper_pak [ Tue Oct 17, 2023 6:46 am ] |
You might find some at a swap meet also. |
Author: | Rick Covalt [ Tue Oct 17, 2023 7:49 am ] |
Actually I feel like I can build a better piece than the stamped factory pieces. Time will tell shortly. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
