It is currently Sun May 12, 2024 2:14 am
PostPosted: Tue Feb 06, 2024 6:17 am
Car Model: Dart
I have a 1965 Dart with a Slant 6. I have found an 8 1/4 rear differential that I would like to put in and get rid of the stock (whinny)
7 1/4. Will the 8 1/4 fit? Do the drum break backing plates match up and bolt onto the 8 1/4? Any help and input would be appreciated. Thank you in advance.
PostPosted: Tue Feb 06, 2024 6:23 am
Depends on what model vehicle the 8 1/4 was in
No the 7 1/4 rear barkes will not swap over.
The 8 1/4 will be large bolt pattern where the 7 1/4 was small bolt pattern.
66 Valiant Signet 225 nitrous
PostPosted: Tue Feb 06, 2024 6:34 am
Car Model: Dart
Thank you Charrlie.
PostPosted: Tue Feb 06, 2024 8:31 am
what vehicle was the 8 1/4" axle originally from? That will be the big factor here.
realistically only A or F/J/M Bodied donor cars axles will work, but with the flat rear wheel arch openings the F/J/M Axle will require a high positive offset / nonstock wheel.
I run a '69 Road Runner in my '64 Dart - it's is a bit too wide - I will be switching it to a '67 Satellite Rear axle someday.
Good luck,
PostPosted: Sun Feb 11, 2024 9:55 am
SL6 Racer
I installed an 8 1/4 assembly in my 1972 Valiant. Not sure what it came out of. It's a bit wider.
Users browsing this forum: No registered users and 22 guests
