It is currently Sat Apr 27, 2024 9:57 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: disstributor springs
PostPosted: Sun Apr 28, 2002 7:46 am
at what rpm should i have full mechanical advance on a stock motor with the super six? i mostly shift between 2500 and 3000 rpm's. cruising rpm's in o.d. at 70mph is 2200.
-i know this is not very accurate but the only tach is inside the truck. i held the accelerator at 2000 rpm and noted the sound then reved the throttle slow until i had max mech advance(about 24 deg btdc without vac adv hooked up) and by sound i was well under 2000 rpms.
i can unhook the vacuum advance and drop to 6 deg btdc and it will still ping at wot and the engine feels sluggish. i'd like to keep it around 10-12 deg btdc, do i need to use two heavy springs.-----------------
welcome to my nightmare
dodgecrazy@aol.com
 Post subject: Re: disstributor springs
PostPosted: Sun Apr 28, 2002 11:18 am
(User Above) wrote:
: at what rpm should i have full mechanical
: advance on a stock motor with the super six?
: i mostly shift between 2500 and 3000 rpm's.
: cruising rpm's in o.d. at 70mph is 2200.
: -i know this is not very accurate but the only
: tach is inside the truck. i held the
: accelerator at 2000 rpm and noted the sound
: then reved the throttle slow until i had max
: mech advance(about 24 deg btdc without vac
: adv hooked up) and by sound i was well under
: 2000 rpms.
: i can unhook the vacuum advance and drop to 6
: deg btdc and it will still ping at wot and
: the engine feels sluggish. i'd like to keep
: it around 10-12 deg btdc, do i need to use
: two heavy springs.-----------------
: welcome to my nightmare
Sounds like you need a heavy second spring with a shorter end loop. The factory sets the springs up so the light one does all the low RPM work untill the second heaver spring bottoms-out in it's end loop and slows down the mechanical advance for the higher RPMs.
Take a look to see how big the loop is on the second spring.
 Post subject: Spring Theory
PostPosted: Mon Apr 29, 2002 10:16 pm
Can someone write a description of what the springs do in the distriburtor? What are the choices and what do they do? I'd love to know.
Mike
MAndreas@aol.com
