It is currently Thu Mar 28, 2024 10:18 pm
PostPosted: Mon Mar 27, 2017 10:37 am
Car Model: 1982 D150
Hi guys,
I found this in craigslist and i am wondering if this could be used on our slant six.
I cannot buy this at this time, but if it does work, this could be a very easy way to convert to EFI...
I know an adapter will be needed for the intake..
https://orangecounty.craigslist.org/pts/6061754732.html
Slant power!!!
At least I try...
PostPosted: Mon Apr 03, 2017 6:31 am
If what I'm looking at is true, there appears to be 2 sections of aluminum for the intake. That would be fine if there were 6 runners, but I only saw 4. is there more to the kit than what I'm seeing in the picture? If not, them you will need to come up with a different solution or go another route.
PostPosted: Sat Apr 08, 2017 5:29 pm
I don't see any runners, I see an interesting 2bbl TBI unit, & an adapter to
mount said unit to a single hole intake. Sure, why not? I'd call Weber to
ask about what type of signal they're using, & if any stock electronic
Mopar dizzys are compatible, & if not what will be required.
