It is currently Sun May 05, 2024 2:51 am
PostPosted: Sat Apr 10, 2021 1:51 pm
Hello again,
I think I was confused about my MS motherboard? And am curious if it has been modified. I probably should also ask and post on diyautotune.
Motherboard v3.0 2005
Daughterboard v3.01 2005
Is this compatible with MS3? Will I need the daughterboard. Have these boards been visibly modified?
Cheers,
Barnaby
These ones go to eleven...
PostPosted: Sat Apr 10, 2021 2:11 pm
Hopefuly this link works?
https://www.flickr.com/photos/192748385@N06/51107752801/in/album-72157718908222566/
https://www.flickr.com/photos/192748385@N06/51107167107/in/album-72157718908222566/
PostPosted: Wed Apr 14, 2021 1:01 pm
Car Model: 1966 Dodge Dart
That is an MS2 V3.0 board - the main board is a V3.0 and the smaller board is an MS2 daughter card. The MS2 daughter card would be removed when upgrading to an MS3, and you would need the taller MS3 V3.0 case.
Matt Cramer
PostPosted: Wed Apr 14, 2021 3:06 pm
Thanks Matt! I'm curious why thy original owner of my MS would put a v2 daughterboard on a v2 motherboard?
PostPosted: Thu Apr 15, 2021 8:27 am
Everything in the MegaSquirt world has its own version numbers and they usually don't match the version numbers on other parts. The combination of an MS2 daughterboard on a V3.0 main board is one of the most common builds out there; they were designed to work together. (The previous main board was called a V2.2, and intended to work with the MS1 processor, after a very short run of V1.01 main boards. I think there's about 100 V1.01s boards produced before the V2.2 came out.)
Matt Cramer
PostPosted: Thu Apr 15, 2021 10:51 am
V3.0 main board was also designed to be upgraded to MS3 w/that daughterboard, is I think another aspect of what Matt said.
Home of Slant6-powered fun machines
