It is currently Sun May 05, 2024 7:45 pm
PostPosted: Fri Nov 05, 2021 8:04 pm
Car Model: Mazda RX8 slant six swap
I am swapping a slant into a 2004 Mazda RX8. I would like to keep all of the car's electric functionality. A friend swapped a Toyota 2JZ (inline six, OHC) into his RX8. He suggested this ECU. Any experience or thoughts?
PostPosted: Mon Nov 08, 2021 10:08 am
I checked with a local RX8/LS swap guy and he told me this unit would run the slant just fine. He's going to help me choose the throttle body and the injectors. I can use the fuel pump lobe (pump is in fuel tank) or use the distributor if I use coil packs.
PostPosted: Mon Nov 08, 2021 11:01 am
Looks nice. Best of luck with the swap and wiring. I had not heard of that Adaptronic outfit.
PostPosted: Tue Nov 09, 2021 4:56 am
They are in Australia. Big slant fans down under.
PostPosted: Wed Oct 05, 2022 8:44 pm
Looks pricey. Check out the mega squirt.
