Slant Six Forum https://slantsix.org/forum/ |
Location of Voltage Regulator for Dash Gauges https://slantsix.org/forum/viewtopic.php?f=28&t=61506 |
Author: | GreybeardGunner [ Mon Aug 14, 2017 2:54 pm ] |
Post subject: | Location of Voltage Regulator for Dash Gauges |
Hey: Does anyone know the location of the dash gauge voltage regulator for the fuel indicator? Thanks Shawn |
Author: | DusterIdiot [ Mon Aug 14, 2017 3:16 pm ] |
Post subject: | Back of the Instrument cluster |
On the back of the instrument cluster circuit board. for ease of access, you will have to drop your steering column and then pull the cluster to access it. |
Author: | SlantSixDan [ Mon Aug 14, 2017 4:09 pm ] |
Post subject: | |
Maybe/not. What year and model is the vehicle in question? |
Author: | DusterIdiot [ Mon Aug 14, 2017 4:23 pm ] |
Post subject: | It's... |
1973 Dodge Dart... The IVR is right up against the column and pedal support bracket... if he has large hands, it's easier to pull the instrument panel to get it out... given he has had some issue with the gauges... he should look to see if the copper circuit traces on the board are still intact and not rusted/broken. |
Author: | GreybeardGunner [ Tue Aug 15, 2017 3:36 am ] |
Post subject: | |
Thanks guys, I'll give her a whirl... Shawn |
Author: | Louise76 [ Thu Aug 17, 2017 9:47 pm ] |
Post subject: | |
and a box of Bandaids. |
Author: | GreybeardGunner [ Fri Aug 18, 2017 3:27 am ] |
Post subject: | |
I can imagine! |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
