It is currently Fri Apr 19, 2024 2:41 pm
 Post subject: Lean burn dist part #'s
PostPosted: Wed May 09, 2018 7:18 pm
Car Model: 1964 Dart 270
Anyone have part numbers for these so I can search for a NOS unit? Looking to go computer controlled ignition so I want to start with a distributor that is already locked out. Looking for either the single sensor or the dual as long as they have no advance mechanism.
Thanks
Brandon
____________________________
https://www.flickr.com/photos/162600228@N03/
PostPosted: Wed May 09, 2018 8:00 pm
Since they have no advance mechanism or vacuum advance to goof up or mismatch parts, this is one unit you could get from say Autoline on Rock Auto
and not spend for NOS.
I might have one in my pile of parts...
PostPosted: Thu May 10, 2018 10:58 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
I have a NOS dual pickup lean burn distributor I would sell reasonably. I'll have to dig it out of stored parts boxes. I had bought it before I decided to do the HEI conversion, a little down the road. I'll make sure I can find it and check the model/part no., then message you. If you haven't sourced one somewhere else. Mine would be considerably cheaper than any of the rebuilds or new on Rock Auto.
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
PostPosted: Fri May 11, 2018 11:03 am
Found mine. Mopar 4145751. Dual pickup, no vacuum advance. I had used the oem cap and rotor, so they're not included.
PM sent to OP.
