Slant Six Forum https://slantsix.org/forum/ |
Starter question https://slantsix.org/forum/viewtopic.php?f=28&t=62419 |
Author: | dirtyd100 [ Tue May 29, 2018 8:02 pm ] |
Post subject: | Starter question |
Doing a trans swap from a 903 3 speed to an 833OD. The 3 speed was set up with a low mount starter and I need to install a high mount starter for the 4 speed. What would be some recommendations for a new starter. I have seen everything from a V6 Dakota to a Hemi mini starter. Any suggestions would be great and the most frugal choice would be best. Thanks |
Author: | DusterIdiot [ Tue May 29, 2018 9:09 pm ] |
Post subject: | Re: Starter question |
1992 Dodge Dakota Starter V-6 or V-8 is the easiest 'cross reference'. These are typically about $35 tops at local junkyards and fit all common high mount starter applications... |
Author: | dirtyd100 [ Thu Jun 14, 2018 6:02 pm ] |
Thanks again DI, do I need to remove anything from this starter as my truck has a relay for the starter? Thought I read something about this but can't seem to find it again. Thanks again |
Author: | DusterIdiot [ Thu Jun 14, 2018 6:26 pm ] |
Is it a relay or solenoid? The 10 tooth starter equipped vehicles had the relay, and no mods needed... the 9 tooth starter circuit will need to change as the starter already has the solenoid... |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
