Slant Six Forum https://slantsix.org/forum/ |
Is there any way to adjust the voltage output? https://slantsix.org/forum/viewtopic.php?f=28&t=62591 |
Author: | Greg Ondayko [ Sun Jul 15, 2018 9:06 am ] |
Post subject: | Is there any way to adjust the voltage output? |
Is there any way to adjust the voltage output on an internally regulated alternator? My voltage on the race car drops to 12 or so when ign coils(6) are on + fuel pump+ elect fan+elect water pump. I would like the voltage to remain at 14 while these run.. Is it just time to investigate a higher amperage output alternator? Greg |
Author: | Rick Covalt [ Sun Jul 15, 2018 9:34 am ] |
Post subject: | Re: Is there any way to adjust the voltage output? |
You can also go to the 16V battery like Ryan did on his race car. |
Author: | Greg Ondayko [ Sun Jul 15, 2018 12:05 pm ] |
Isnt that for a total loss system without an alternator? Greg |
Author: | DadTruck [ Sun Jul 15, 2018 12:27 pm ] |
Greg, Are you seeing the 12v at idle or with the motor turning RPM’s above 1200? If it is that low above 1200 RPM, I would take the alternator to an AZ or similar shop and get it tested, The electrical load that you have should not be a challenge for a 70 amp alternator. These are my guesses 25 amps electric fan 10 amps electric water pump 10 amps electric fuel pump 15 amps coils You can check the manufacture’s catalog and get the exact current draw for each component and then sum up what you need. |
Author: | Rick Covalt [ Sun Jul 15, 2018 1:23 pm ] |
Quote: Isnt that for a total loss system without an alternator? Yes that is what he has, sorry |
Author: | Greg Ondayko [ Sun Jul 15, 2018 4:04 pm ] |
Rick Covalt wrote: Quote: Isnt that for a total loss system without an alternator? Yes that is what he has, sorry No problem. Greg |
Author: | Joshie225 [ Sun Jul 15, 2018 4:47 pm ] |
You've given the voltage at the volt meter. What's the voltage at the alternator output at idle? At 2500 RPM? |
Author: | emsvitil [ Sun Jul 15, 2018 5:09 pm ] |
Spin the alternator faster...…. |
Author: | Greg Ondayko [ Mon Jul 16, 2018 7:32 am ] |
Joshie225 wrote: You've given the voltage at the volt meter. What's the voltage at the alternator output at idle? At 2500 RPM? I would have to check on that one, and get back to you. Greg |
Author: | Dart270 [ Mon Jul 16, 2018 8:02 am ] |
What is the belt drive ratio (crank pulley diam to alt pulley diam)? Might be spinning too slow at idle. What happens to voltage if you raise idle speed? Lou |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
