Slant Six Forum https://slantsix.org/forum/ |
Timing marks are gone https://slantsix.org/forum/viewtopic.php?f=28&t=62945 |
Author: | 1987Vera [ Mon Oct 22, 2018 11:46 am ] |
Post subject: | Timing marks are gone |
Thanks in advance for your help (no pun intended) On my 1987 Dodge D-100 the timing mark lines are visible, but no numbers to tell where I am. I bought the Chrysler service manual in hopes there would be a pic, but it too has cryptic symbols. There are 10 lines, but where is Zero? in the middle, on the top? Also it is supposed to be timed to 12 or 18 BTDC for manual or auto trans, so how are 12 degrees of timing going to help me on a scale of 10? Do I just imagine that 12 is two imaginary tics past the end of the marks? Thanks. Vera. Attachment: Attachment:
Author: | and739 [ Mon Oct 22, 2018 1:39 pm ] |
Post subject: | Re: Timing marks are gone |
Welcome to the forum! It's a great place to be. Good timing (again with the puns), I just happen to have a recent pic of my timing tab of which I had just finished freshening up the numbers on. Attachment: timing tab.jpg [ 63.42 KiB | Viewed 4948 times ] It looks to have the same shape as the one on your engine, just with the engraved numbers. The lines are 2 degree increments. Anyway, I hope this helps! |
Author: | 1987Vera [ Mon Oct 22, 2018 2:38 pm ] |
Thanks SO much! I scoured the internet for days, bought books and manuals looking for a picture of what you just sent. |
Author: | hank2 [ Tue Oct 23, 2018 10:06 pm ] |
I'm glad for this thread, as I needed the same info. My tab is knackered as well. I actually purchased a decent tab for my D150 on ebay about 6 months ago. Then it promptly disappeared at home never to be found. I didn't have it long enough to really take a look at the markings. I was going to try to glue a piece of timing tape on the tab for the correct diameter dampener. I still may do that if I ever get a chance to verify true TDC. |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
