http://slantsix.org/forum/
Distributor Grease
http://slantsix.org/forum/viewtopic.php?f=28&t=63768
Author:  crickhollow [ Thu Jun 27, 2019 10:44 pm ]
Post subject:  Distributor Grease
What type of grease/oil should I use on my dizzy?
I have a 62 Valiant with a Bosch dizzy which has been completely dismantled and cleaned.
Thanks
Author:  DadTruck [ Fri Jun 28, 2019 7:45 pm ]
Post subject:  Re: Distributor Grease
for the shaft, I use a quality synthetic grease like Mobil 1 Red, although engine oil would also suffice
for the pins that the centrifical advance weights run on, I use a thin coating of dry film moly, as found at
http://kanolabs.com/indLub.html
that way you don't have a wet lube that will hold debris or run off
