It is currently Sat Jul 11, 2020 4:59 am
PostPosted: Mon Aug 12, 2019 6:05 am
Car Model*:
I think I found a good way to clean the terminals in the bulkhead connector. Don't know if it will be OK long term, or on heavily corroded terminals.
I unplugged the connector, and removed from the firewall. Then put white vinegar in a freezer bag, submerged the connector in the vinegar and put a rubber band around the bag/wires, and let it soak for awhile. Dumped the vinegar and replaced it with water, then rinsed with a baking soda solution in the bag to neutralize the acids. Dried with air pressure, and hair drier. Then coated the connectors with dielectric grease prior to plugging back together.
66 Valiant Signet 225 nitrous
PostPosted: Mon Aug 12, 2019 6:57 am
Car Model*:
You didn't mention you did it, which you might have, but I would have included at least one post baking soda wash with at least one pure water wash, and I think the dicelectric grease is probably the most underrated preventive solution for this connection.
PostPosted: Mon Aug 12, 2019 12:53 pm
Car Model*:
Didn't mention it, but yes, I did a pure water wash after the backing soda bath
Users browsing this forum: No registered users and 22 guests
