Slant Six Forum https://slantsix.org/forum/ |
Bulkhead Connector '63/'64 https://slantsix.org/forum/viewtopic.php?f=28&t=63900 |
Author: | JimKueneman [ Mon Aug 05, 2019 11:45 am ] |
Post subject: | Bulkhead Connector '63/'64 |
Year One (M&H Harnesses) shows 1964 Dart harnesses but not 63. After looking at the '63 harness it look much different than later Mopars where they broke it out into 3 separate harnesses under the hood at the bulkhead. Anyone know if the bulkhead connector is the same between '63/'64. Maybe not the pin out put will they physically plug together? Thanks. Jim |
Author: | drgonzo [ Mon Aug 05, 2019 12:19 pm ] |
Post subject: | Re: Bulkhead Connector '63/'64 |
That's a good question, as my '63 sure could use some new wiring. I am surprised Dan hasn't tackled this one. |
Author: | MadScientistMatt [ Fri Aug 23, 2019 9:47 am ] |
Got a picture of the connector? Most of the connectors Mopars used at the time are Packard 56 series. |
Author: | Greg Ondayko [ Fri Aug 23, 2019 6:51 pm ] |
Here is one on a stockish 64. 2 connectors not 3. Greg |
Author: | MadScientistMatt [ Mon Sep 09, 2019 11:31 am ] |
In that case, I suspect they're the 56 series. Del City is a a good supplier for small quantities, if a bit on the pricey side. https://www.delcity.net/store/Packard-5 ... ors/p_9108 |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
