It is currently Sat May 18, 2024 8:23 am
PostPosted: Wed Nov 29, 2023 12:08 pm
Car Model: Valiant 100
1966 Plymouth Valiant 100, the temp gauge seems to be fine. The gas gauge shows full when the tank is full, but after about 3 or 4 gallons usage it shows empty - goes down rather rapidly. We replaced the sending unit and cleaned out all the contacts behind the instrument cluster. I have read the article about the instrument cluster voltage regulator, but since the temperature gauge seems fine am a bit confused. Any help is appreciated - thanks.
PostPosted: Wed Nov 29, 2023 12:59 pm
Did you replace the Sending unit with a new spectra premium Unit?
Those have a resistance curve that is known to be waaay off of what they should be!
