It is currently Fri Apr 19, 2019 9:27 pm
PostPosted: Sun Oct 14, 2018 7:36 pm
Car Model*: 62 Lancer GT
Im changing oil pans to put a later motor in my 62 lancer. I will be putting a turbo on at some point. I want to add an oil return fitting in the pan now. Would like ideas on what fitting to use and where to place it. Have been looking at the fittings on ebay like this one
https://www.ebay.com/itm/5-8-Oil-Pan-Dr ... 2ab8332f25.
Any ideas would be appreciated.
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Sun Oct 14, 2018 7:40 pm
Car Model*: 64 Plymouth Valiant
I'd use an AN fitting like that.
Then braided AN hose from turbo(AN fitting too) to pan.
PostPosted: Sun Oct 21, 2018 3:29 pm
I looked at an fittings, it does get expensive.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Sun Oct 21, 2018 6:57 pm
Sometimes it's cheaper to get a NPT fitting then an adapter to go to an AN fitting...…………..
PostPosted: Mon Oct 22, 2018 3:27 am
Car Model*:
John,
I welded a piece of steel plumbing pipe to my pan (3/4 NPT). For the return line, you just need a large diameter hose that can withstand the heat near the turbo exh housing, and there is very little pressure. I bought a cheap tapered (AN-NPT) adapter fitting at a hose supply place to make an adapter but you could also just use NPT fittings and hose clamp the hose on. Depending on the car, you may want to go forward from where I have mine. I did one for a 64 Valiant and it ran into the steering box mount a little, so further forward might be good. That pan is currently on the LeMons racecar, so I can't look at it now.
Also, where do you plan to put the turbo? That will determine somewhat where you put the drain line fitting in the pan. You want the drain line to be as vertical as possible.
Hope this helps,
"You mean you still have a Slant 6 in that thing?"
PostPosted: Mon Oct 22, 2018 4:45 am
Car Model*:
Two other recommendations
1) Make sure the entrance to the pans is above the oil level
2) have the fitting in the pan inline with a main bearing cap/saddle, to reduce windage, of the oil being inline with the rotating assy. (rods and counterweights)
66 Valiant Signet 225 nitrous
PostPosted: Sun Nov 04, 2018 1:17 pm
Well finally have time to get back to work on the Lancer. I looked at mounting near the mains #2 is behind motor mount, #3 is not that vertical but doable. The only other place is center of crank between the con rods. Does any one have a measurement of the oil level on an early slant pan? Got an AN bolt on fitting from a local engine builder, the only thing I dont like is the nut is 3/8 inch thick, which makes for clearance issues, might have to break out the welder.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Mon Nov 12, 2018 3:27 pm
Got to try out my new step drill.
Found a good weld on fitting, the step fit tight in the hole and made welding set up easy.[attachment=0]
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Tue Nov 13, 2018 5:09 am
Car Model*:
Cool fitting.
PostPosted: Thu Nov 15, 2018 4:04 pm
Yes worked out good. Fit tight I dont even think Ill weld the outside. Maybe some JB weld.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Thu Nov 15, 2018 4:22 pm
It was cheap to, $8.99 for 2 with free shipping. Tried to get it near the main but ended up at the counterweight. .....
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Fri Nov 16, 2018 2:06 pm
Car Model*:
Please post the fitting source/link/part number when you get a chance.
The oil just dribbles out so I would not (and did not) worry about location near counterweight or whatever else.
PostPosted: Sun Nov 18, 2018 6:15 pm
https://www.ebay.com/itm/AN10-10-AN-QTY ... 1438.l2649
Hope this works
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Mon Nov 19, 2018 5:19 pm
Car Model*:
Thanks!
