It is currently Thu Jul 18, 2019 4:01 am
Post new topic  Reply to topic  [ 123 posts ]  Go to page Previous 15 6 7 8 9
PostPosted: Thu Jun 20, 2019 4:06 pm
3 Deuce Webber
Car Model*: Valiant -66 turbo
[imgImage][/img]
Pic of the adapter , sample mounted in the engine bay.
The brass couplings is water to the turbo
One of them (pressure) is coming by a T- connection from a heater hose.
Pic down, is the return from turbo.
I tried different possible positions for the two turbo cooler lines.
By use transparent hoses, i could se when the water circulated. Or not..
Im using Davies Craig electric pump, sometimes it circulate the water quite modest, and when hot whith a lot more pressure.
My first test was with two T-connections from the heater hoses. But the water was nearly not circulate at all.
Now i think it will work, hopeful also when water is hot.
The best Thomas
[imgImage][/img]
PostPosted: Sat Jun 22, 2019 8:35 am
3 Deuce Webber
[urlImage][/url]
Pic of the support bracket mounting bolts
Pic of the support bracket. when the bolts are tightened it will press against the adapter and support it.
But is anyway free to expand/retract during the heat cycles.
Try to minimize the risk for cracks in the cut manifold..
[urlImage][/url]
Thomas
PostPosted: Sun Jun 23, 2019 4:20 am
Car Model*:
Thanks for the nice pics.
I hope you are having a nice summer of cruising in Sweden!
"You mean you still have a Slant 6 in that thing?"
