It is currently Fri Mar 29, 2024 12:46 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun Jun 30, 2013 6:12 pm
Also my 62 valiant was a power steering car. I have a bunch of pics of the engine bay with my original turbo manifold? But if you put the turbo in or around the battery box it will discharge oil well and fit just about any application minus AC
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Sun Jun 30, 2013 6:29 pm
I like it! I just worry that a Fram oil filter could kill the engine collapsing like they have been known to do. :lol:
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
 Post subject: Filter, schmilter...
PostPosted: Sun Jun 30, 2013 7:00 pm
So, if you're that paranoid about it, run a different one... no problemo.... :)
1964 Valiant 4-door sedan, 225 turbo/904
 Post subject: Re: Filter, schmilter...
PostPosted: Mon Jul 01, 2013 6:53 am
I do! Brand new rebuild on my van I could only get 20lbs of pressure with a HV Melling pump, and the rods rattled on start up. Changed to a Pure and problem was fixed. Step daughter's Lumina had one collapse and kick a rod.
PostPosted: Mon Jul 01, 2013 9:56 am
That's too bad. I hate to hear of product failures like that.
I, personally, have used FRAM filters on all my vehicles since I started driving in 1955, and have never had a problem of any kind...
So, I can see your pont, but you can see mine as well...
PostPosted: Mon Jul 01, 2013 9:57 am
So, I can see your point, but you can see mine as well...
