It is currently Wed May 22, 2024 1:09 pm
PostPosted: Thu Jan 28, 2016 3:41 am
just wondering how far any of you guys have gone timing wise with a stock cammed slant? i am keeping mine at what i think is pretty conservative at the moment, only winding 12deg into it with 5psi,
to keep things simple, here's a screenshot of my current situation, im currently working on my VE table before i start winding any timing into it, i will also wind the boost up a bit more,
annnd my current setup is
MS2
6x LS2 coils
36-1 trigger wheel
rx7 series 5 hitachi turbo
PostPosted: Tue Feb 02, 2016 2:41 pm
My turbo slant is a race-only application with no street driving at all, ever.
Because of that, I don't worry about gas mileage, engine heat or driveabiity.
That allows me to run what the engine likes for power.... which seems to be 18 degrees.
I have an old Lean Burn slant six distributor that came with NO centrifugal advance mechanism and no vacuum advance diaphragm; the plate is locked down, solid. So, it starts and runs all the way to its 5,500-rpm redline, with 18 degrees of advance.
It seems to like that.
I could not get away with that on the street.
Bill
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Tue Feb 02, 2016 4:34 pm
Yep slightly different application.
how much boost are you running and do you have any idea of your intake temps etc,
What fuel do you run?
I am up to 15 deg at around 6psi now, but I lost my fuel pump yesterday, luckily it died off throttle was 2nd hand unknown condition.
I have a new one on the way now, slightly painful as it's an in tank setup
PostPosted: Sat Mar 12, 2016 9:15 am
Hey Kcuf,
Do you have any detonation problems running that much advance?
I'm trying to plan ahead to take the steps to prevent detonation in my build, because I don't have it assembled yet.
Any tips for me?
10-12 psi
Stock 225
Intercooled blow through
IAT sensor installed.
What's this screw for?
'76 D100
PostPosted: Mon Mar 14, 2016 2:08 am
gtb123 wrote:
Hey Kcuf,
Any tips for me?
10-12 psi
Stock 225
pre turbo i was having the odd bit of detonation at part throttle up steep hills on a hot day, but i think i'd sorted that out with the above maps, i haven't had any detonation at all since boost, which is how i am planning to keep it all things going well.
My maps have changed a bit since then also, i will grab a screenshot of the current setup and re-post where I am at now.
I am still running no cooler, so timing is still pretty conservative, I do need to either shim my springs or replace them as i am pretty sure even at 5-6psi it is hurting power north of 3500 or so rpm.
This is my first boosted slant so i cant say i really have any awesome advice, other than keep it conservative and work your way up, what are you going to be using for ignition control? by blow through I am guessing you are going carb?
PostPosted: Tue Mar 15, 2016 6:22 pm
Yeah it's carbureted.
I'm going to use HEI with a standard cap and rotor on the stock distributor. From what I understand, I have to retard thd timing to an extent in order to prevent detonation when using pump gas.
I want to avoid retarding it if I can so I don't have sluggish start ups, so I was wondering how many degrees people have played with on a stock slant with an IC.
We'll see though! Definitely going to start conservative and push it to a reasonable location.
'76 D100
 Post subject: Timing
PostPosted: Thu Aug 18, 2016 3:10 pm
For my build I used a regular super six dizzy, I believe w the 9R slot. I then used the spring kit that is sold by one of the memebers (check in appropriate area) dont remember the colors but I did set my timing to 23*. I also run a 5 pin hei module from an 80's toronado. The small 5th pin when grounded pulls 5* timing which in turn limits me to 18* total. That 5th pin I set up on a hobbs switch to 5# of boost.
So, 23* timing max, bosst builds to 5#, hobbs switch closes which grounds out the toronado hei module and pulls 5* and I end up w 18*. This is all at 10# total boost with a blow through, intercooled setup. Builds noted under turbo d150 i believe.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
