It is currently Tue Jan 28, 2020 8:53 am
 Post subject: Head porting
PostPosted: Sun Apr 16, 2017 2:37 pm
3 Deuce Webber
Car Model*:
I plan to gasket match ,debur intake and exhaust . Installing larger engine builder valves
I'll be running 6-9 lbs of Boost with super charger
So I am assuming I can
polish the exhaust port smooth ??
Intake is normally left semi rough to help fuel mixture is this true on forced induction ??
And the chamber on the head polished smooth or rougher as cast finish ??
Thank you all
1963 Plymouth Valiant Wagon
PostPosted: Fri Apr 21, 2017 1:13 pm
3 Deuce Webber
Car Model*:
Pulled the valves and Ran the head thru the washer few times all clean 👍👍
I magnafluxed it all is good ready to start with port and polish
Let the fun begin !!!!
PostPosted: Mon Apr 24, 2017 2:03 pm
Car Model*: 1965 Plymouth Belvedere I
Be careful removing material. Especially in the area where the two valve bowls are next to each other. Don't ask me how I know.
-Matt
-Matt
http://www.MattmansMopars.com
Strive for Excellence, not Perfection.
