It is currently Thu Apr 18, 2024 5:11 am
 Post subject: Eaton over slant 6
PostPosted: Mon Jun 05, 2017 11:35 am
Car Model: 1966 2D Dart
After too many years with performance of +/- 16s I like to go next level. A supercharger over slant six sounds crazy enough.
Does Eaton M90 fit under early a-body (1966) hood? From which car the Eaton has long enough snout that the compressor comes over intake opening?
I like to keep my 4bbl Clifford / injection / Dutra duals as they are. Just made low compression bottom end with blower cam. Current motor is milled over 10:1 and it has to go away.
Which pistons are used in such application?
Which cam? Like to get red line over 6k.
1966 Dart. 170 cu.in. 200 rwhp.
PostPosted: Wed Jun 14, 2017 1:19 pm
Aussiespeed sell drive snouts which bolt to the front of Eaton superchargers.
http://www.aussiespeedshop.com/product- ... assemblies
This would centralize the supercharger over your inlet manifold .
You may have to make an adapter to go between your supercharger and inlet manifold or maybe adapt one of these
http://www.aussiespeedshop.com/product/ ... -baseplate
DRIVE IT,DON'T HIDE IT
PostPosted: Sat Aug 05, 2017 11:12 am
Image this is the one I made for 4-71 blower. Image this is the one I made for the 4-53 blower, this was harder because the 4-53 series need oil feed to the rotors end bearings.
Last edited by terrylittlejohn on Sat Aug 05, 2017 11:25 am, edited 1 time in total.
PostPosted: Sat Aug 05, 2017 11:18 am
Wow, for what Aussiespeed charges for a blower snout you can buy a new Borg Warner turbocharger. Dart270/Lou uses Dutra Duals on his turbo Dart.
