It is currently Mon Mar 30, 2020 7:06 pm
PostPosted: Mon Mar 02, 2020 9:52 am
Car Model*: 1966 Dodge Dart
Although this is the fourth turbo combination I've run, it's my first engine rebuild. Thanks to coconuteater and Charlie S for donating several parts, and also to the others who'd offered to help. Today this build got started with dropping the parts off at the machine shop. One BH code block:
File comment: One BH-code block
And two small torque converter cranks:
File comment: Two small torque converter cranks
Matt Cramer
PostPosted: Mon Mar 02, 2020 11:59 am
Online
Car Model*:
Matt, I would Highly recommend the Oiling system mods Doc Proposes in this document.
http://www.slantsix.org/articles/dutra- ... blocks.htm
Happy building and boosting. - with the Power and tunability ( ability to make more power) that you will infuse onto the slant you will want those parts to be skookum as frig!
Happy Building and Boosting!
Greg Ondayko
69 Dart http://www.youtube.com/hyperpack
PostPosted: Thu Mar 19, 2020 8:42 am
No progress this week as I'm working from home and the car's at the shop at work. But last week I got a few pictures of doing Doc's water pump block mod. I know, should have done that before taking it to the machine shop, but better late than never!
This block had a big ridge in the water pump cavity.
Let's make some sparks.
The final result.
Matt Cramer
PostPosted: Mon Mar 30, 2020 1:26 pm
I tried to use some grease to keep debris out of the oil galley while doing Doc's oil galley porting mod.
It did not work quite as I had hoped.
Matt Cramer
PostPosted: Mon Mar 30, 2020 2:08 pm
Car Model*:
Ouch. I always take some time and do all my grinding and dirty prep before I take the engine to the shop to get cleaned up and machined. You can do grinding afterwards before assembly, but it's a pain to clean everything...
"You mean you still have a Slant 6 in that thing?"
PostPosted: Mon Mar 30, 2020 5:55 pm
Online
Car Model*:
Blast that clean with brake cleaner and pipe brushes before assembly!
Greg Ondayko
