It is currently Sun Jun 02, 2024 5:58 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sat Apr 20, 2024 4:42 pm
Sounds Good.
Thank you Karl.
PostPosted: Sat Apr 27, 2024 1:18 am
Car Model: 1964 Valiant 2dr post
Hi Guys:
Like I said, I haven't forgotten this post. I received the Laser parts late this week, fixed the laser and cut some test parts that turned out really nice. Now I'm in the middle of a very busy weekend at this facility. By the end of the week, I will cut test files, checked fitment, and posted the final, workable, DXF/DWG that can be used by any laser, plasma, waterjet cutting firm to produce a valve cover spacer or gasket.
Sorry it's taking so long, but this isn't my day job, just something I'm lucky enough to have access too.
Karl
64 GTO...10.80's@122 on street radials
Destroked 455, Qjet, stock ign, 2400 stall
64 Valiant
Old 225, 4spd, 2.92-8.75, 2bbl, headers
dual 2.25"
PostPosted: Wed May 01, 2024 3:25 pm
Hi Guys,
Finally got the parts for the laser and repaired it. Modified drawing with wider corners and corrected length. Last night I burned another template and it fits great.
Unfortunately, the forum software will not allow me to attach .DXF or .DWG drawings. It doesn't allow those extensions. I tried uploading after renaming without the extension included, but the forum recognized the the file types anyway.
So if you want the files I will need to email them to you. PM you're email address, and I'll forward a copy of the files.
I went to sendcutsend.com and quickly got a laser quote. I've found Send Cut Send to have the lowest prices for smaller quantities than other online laser cutters, and the service and quality has been excellent.
Prices include shipping.
Least expensive:
1/4" Aluminum 2024 T3
1 Spacer = $70.49
2 spacers = $49.34ea or $98.68 total to your door.
Note: ***They do not offer 3/8" in 2024 T3 alloy.
Least expensive 3/8":
3/8" Aluminum 5052 H32
1 spacer = $148.70
2 spacers = $102.80ea or $205.60 total
6061 alloy is quite a bit more expensive.
Gearhead
AKA Karl
64 Valiant
dual 2.25"
PostPosted: Mon May 06, 2024 5:51 am
Thanks for the work Karl!
PostPosted: Wed May 08, 2024 1:34 pm
Car Model: 64 Valiant
gearhead wrote:
Hi Guys,
Least expensive:
1 Spacer = $70.49
1 spacer = $148.70
Gearhead
AKA Karl
I asked Chuck several years ago if he would make it possible to post CAD files such as dxf and dwg extensions within the CAD/CAM discussion subforum and he did. I've shared some of mine with people on here before. Wonder why its no longer working....?
PostPosted: Mon May 13, 2024 6:17 am
Here are the Links to Karl's Files:
Valve Cover Gasket / Spacer .DWG File
- and -
Valve Cover Gasket / Spacer .DXF File
