It is currently Sat May 18, 2024 11:17 pm
PostPosted: Fri Dec 31, 2021 7:27 pm
Someone on FABO has created a 3D file to create the speaker grills.
This would be a great item for one of the members with a 3D printer
https://www.forabodiesonly.com/mopar/th ... nt.507971/
PostPosted: Thu Jan 06, 2022 8:19 pm
Nice design!
PostPosted: Fri Jan 07, 2022 8:47 am
Follow up post.
Seems they are made in Oz and can be found here:
Pretty sure they've been available in Australia for a while now as a reproduction item. I know some place does them like the original material, but there's also these ones....
PAINTABLE SPEAKER GRILLE : RV1/SV1 VALIANT (retrosoundusa.com.au)
STAINLESS-STEEL SPEAKER GRILLE : RV1/SV1 VALIANT (retrosoundusa.com.au)
PostPosted: Fri Jan 07, 2022 2:17 pm
If you go to buy one of the repro plastic ones, make sure they've solved the problems before you spend the money.
Paintable steel looks nice. Stainless steel??? No way! Wrong material unless you like your eyes getting stabbed with sun reflections (and even short of that, your vision impaired by reflections off the windshield.
